Daewoo Broken camshaft Sensor
ALL OTHER MAKES ALL OTHER MODELS
ZAYNE
I have a daewoo leganza, which has been making a lot of noise when I my foot is stopped and running, accelerating poorly, and getting no pickup. I took it to Meineke and was told that its catalytic converter was broken. However, when I took it to the Daewoo dealer, I was told that the catalytic converter, which is under warranty was not the biggest problem, but that the camshaft sensor was broken and need replacement and will cost about $200. I am going to trade this car after I repair it, but I do not want to spend too much money on it. Do you think that the car will run fine once the catalytic converter is fixed, or should I also fix the sensor?
Feb 23, 2006 at 2:49 PM
PEPPERMRJ
  • 1,158 POSTS
What year? There is another post on a camshaft sensor. https://www.2carpros.com/forum/daewoo-leganza-2002-with-52000-miles-vt4158.html
Cam sensors have quite a lot to do with the timing and spark plugs firing. I would think that it is what caused the cat. convertor to clog. So, yes I think you will have to.
Feb 23, 2006 at 3:46 PM
