I have a1994 Chevy Camaro 3.4 liter. Here is my problem and I am getting frustrated with it. I start the car and it idles a bit high 1200 rpm with a very slight miss.When put into gear idles at 1000 rpm when the car warms up to closed loop temp it will idle at about 1300 then when put into park or neutral it shoots up to 1800+ rpms. Oh and the check engine light comes on when it is at a stop after a few minutes due to the high idle. I put a jumper in and get no code flashes at all.
I have replaced the Map sensor, Coolant Temp sensor, PCV valve, IAC valve, TPS, Plugs wires and cleaned all components. Checked for vacuum leaks and found none.
The car also when it warms up will cruise at like 25+ MPH with out giving it gas. I have a new ignition control module due to get here Monday and 3 new coils. What am I missing to get this idle under control.
Oct 4, 2008 at 11:53 PM
