99 dakota transmission trouble
1999 ALL OTHER MAKES ALL OTHER MODELS
GKBOST
I have a 99 Dakota automatic transmission, 3.9 v6 The truck has 64xxxx miles. The first couple of times through the gears it has a hard time getting from 2nd to 3rd. all other gears are fine. After engine heats up the problem goes away. Transmission or filter/fluid?
Feb 28, 2007 at 2:32 PM
CHEVY22
  • 1,375 POSTS
you could try a flush but this one sounds internal , possibly the pump or converter going south , but if the fluid is dirty try the flush first and go from there , if you need more help let us know and if the engine light is on have it checked and get back to us
thanks , jim
oh and if you are happy with the info please leave some feedback we all donate out time here helping people for free
Feb 28, 2007 at 2:52 PM
SHORTYBOY
  • 7 POSTS
I too have a transmission problem.
In high gear, there seems to be a bounce in the RPM's, especially when I hit bumps or accelerate. I am hoping this is caused by a faulty solenoid or sensor somewhere. Currently I am getting a P0505 code which pertains to the idle speed motor. I cleaned this with Carb cleaner, and the transmission problem has only happened since this cleaning. Could a new Idle sensor be the fix?
Any help is greatly appreciated.
Shorty.
Mar 1, 2007 at 6:24 AM
CHEVY22
  • 1,375 POSTS
yes always replace them , the problem is the circuit is malfunctioning meaning it is shorting internally and clear the codes and see what happens and get back tp ud
jim
Mar 1, 2007 at 6:32 AM
SHORTYBOY
  • 7 POSTS
Sorry,
Not all that mechanically inclined...What do you mean by TP UD?
Mar 1, 2007 at 7:32 AM
CHEVY22
  • 1,375 POSTS
sorry typo i meant get back to us , replace the iac
jim
Mar 1, 2007 at 8:08 AM
GKBOST
just checked the fluid ... it appears clean and doesn't smell. My local mechanic says the transmission has to be replaced..then he asked me how much I wanted for mt truck. ?????
Mar 1, 2007 at 10:16 AM
CHEVY22
  • 1,375 POSTS
get a second opinion and replace that iac before you do anything , just my opinion
thanks , jim
Mar 1, 2007 at 11:42 AM
