97 lumina staaling on right turns only
1997 ALL OTHER MAKES ALL OTHER MODELS
DANWRIGHT2
Hey guys! How's life? I've got a 97 lumina 3.1 with 172000 miles on it. It stalls when I go around a right curve or turn a corner mainly when traveling at 30 mph or higher excellerating or not. I had autozone read the errors and the only thing found was something to do with the overheating problem I'm still having. These errors were read about 8 months ago so I don't remember them. I found a white slugg on the bottom of the radiator cap and in the neck of the radiator- flushed the system twice and installed new antifreeze. The water pump, thermostat and temp sensor have been changed. Now I'm seeing the low coolant light on even with it full, coolant disappears but there's never any on the ground. Mechanics have changed the fuel pump and the ignition switch (when it failed) sighting a loose wire for the stalling. Still doing the same. What do you think time to shoot it? :lol: I heard you guys are the PROS so I know you've got a solution for me. First time viewer.
Dan
Mar 19, 2007 at 9:56 AM
2CARPRO JACK
  • 11,533 POSTS
Right turns only? Try wiggling the wiring harness under the hood while the engine is running, see if it affects it, looking for a bad/broken wire
Mar 19, 2007 at 12:07 PM
