95 Odyssey Major oil leak
1995 ALL OTHER MAKES ALL OTHER MODELS
RZBRANSON
My Odyssey leaks oil A LOT, only when it is running, not from the oil filter or the filter gasket, but from the base of the thing that the filter is screwed into.
When you lay under the car, it appears to be dripping from the bottom of the "thing" I described above. What do I do about this? Thanks!
This leak started rather suddenly, for what its worth
It's a 95 Odyessy, 220,000 miles, 2.2L engine. It is in otherwise great shape.
Mar 17, 2007 at 12:10 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the oil filter adapter.Honda should have all the gaskets and or seals req'd to fix this. Very inexpensive and easy to do yourself
Mar 18, 2007 at 8:52 AM
LOSTINMARS
  • 222 POSTS
take a look at the oil pressure switch. its right above the oil filter housing and i've seen many more of those leak than the filter housing.
Apr 10, 2007 at 2:43 AM
