94 Cherokee rear axle
1994 ALL OTHER MAKES ALL OTHER MODELS
BOBC3187
I have a 4WD 94 Cherokee, 247k and 4.0L 6 cyl. Trying to replace the rear axle assmbly. Its a Dana 35C w/ABS and a 3.07 ratio, the only ratio I can junk yard here so far is a 3.55. Whats the effect if I put a 3.55 in replacing a 3.07???
Thanks
Mar 30, 2007 at 4:43 PM
2CARPRO JACK
  • 11,533 POSTS
Your speedo will be off a little. Do you tow with your jeep? a little lower gear will help that. Might need a programmer to reset the trans shift points for the gear change.
Mar 31, 2007 at 8:41 AM
