93 suzuki swift 1.3lno spark-.66volts to distributor- key on
1993 ALL OTHER MAKES ALL OTHER MODELS
AUDIE BUCKNER
  • 9 POSTS
help!93 suzuki swift has no spark from coil or plug wires-12volts to coil terminals-12 volts to igniter module under coil on one wire-.66 volts to dist. key on at both wires-when cranking engine the dist. has .86 volts=less than one volt!-traced dist. wires to computer connecter-same volts there. engine has been sw :?: itched and brought to me with no spark.tried several parts -no volts to dist. is where problem is i think--help!
Apr 25, 2006 at 11:42 AM
LOSONE
  • 1,616 POSTS
Give me exactly waht it will or won't do. I feel that it may need an ignition module but be more specific about the symptons without voltage readings.
Apr 25, 2006 at 11:47 AM
AUDIE BUCKNER
  • 9 POSTS
no spark-fuel pump runs a few seconds-dash lights work normal-no spark when cranking-tried a new module under coil-still no spark- help and thank you for the quick reply!
Apr 25, 2006 at 11:52 AM
LOSONE
  • 1,616 POSTS
Those 1.3 have a high timing belt failure. Pull the distributer cap turn the engine so the timing mark is on TDC and insure the rotor is pointing to #1 cyl. Good luck
Apr 25, 2006 at 12:00 PM
AUDIE BUCKNER
  • 9 POSTS
hello! dist. rotor movimg when cranking -think timing belt is normal-no spark when cranking-shouldn't there be 12 volts to dist.? tried another computer -numbers different-no spark.help? thanks!
Apr 25, 2006 at 12:40 PM
LOSONE
  • 1,616 POSTS
There should be 12V to the distributer. Check all fuses especially to the ECM
Apr 25, 2006 at 1:35 PM
AUDIE BUCKNER
  • 9 POSTS
all fuses good under hood and dash.don't know where dist. gets voltage from.i know the 2 dist. wires go directly to computer terminals.i have old engine and have traced all wires.i need wiring schematics to maybe see where power comes from .i have many manuals;but none precise for swifts.thanks!help?
Apr 25, 2006 at 2:21 PM
LOSONE
  • 1,616 POSTS
The GM geo metro of that year is the same vehicle and the wiring the ame. The 12V comes from the ignition switch.
Apr 25, 2006 at 2:55 PM
AUDIE BUCKNER
  • 9 POSTS
gonna give up for today;and try to look at a schematic .thank you for your time today!
Apr 25, 2006 at 5:22 PM
AUDIE BUCKNER
  • 9 POSTS
hi! got to do a little on car today-looked in factory shop manual for a couple hours. dist. voltage with key on should be .04 to.08 volts-and it is.got resisistances for several parts and test procedures. hope to find something defective. also checked air gap in dist.-it had no gap at all! set to .008+ - switched two relays in fuse block.got more to check tomorrow. thanks!
Apr 26, 2006 at 9:25 PM
AUDIE BUCKNER
  • 9 POSTS
help!still no spark-got code 41 -no dist. signal-car has same voltage at 2 dist. wires and 2 terminals on computer-resistances for pickup,coil all normal.does anyone think it is computer? help! thanks!
Apr 29, 2006 at 3:29 PM
LOSONE
  • 1,616 POSTS
As much as I hate to say it, it might be the little processor.
Apr 30, 2006 at 1:52 PM
AUDIE BUCKNER
  • 9 POSTS
WHAT AND WHERE LITTLE PROCESSOR?THANK YOU FOR ALL YOUR REPLYS! THE COMPUTER IS OVER 1300$ RETAIL.
Apr 30, 2006 at 9:13 PM
AUDIE BUCKNER
  • 9 POSTS
I TRIED ANOTHER USED COMPUTER.SAME RESULTS NO SPARK.
Apr 30, 2006 at 9:16 PM
JIMB355
  • 5 POSTS
u said the #'s on the ecu were different than the one on your original ecu? there are several ecu's for these vehicals! u need the correct one!! my mother in-law has a sidekick and i had the same problems as you! i've got on line and had the same luck as you are! i even found a way to test the ignitor with a battery and a volt meter! in the end after weeks of searching i found the correct ecu pluged it in and she fired up and ran!!!!
Oct 25, 2006 at 8:07 PM
