92 Tempo GL Engine Idles High
1992 ALL OTHER MAKES ALL OTHER MODELS
FORDEXPLO
  • 4 POSTS
I recently installed a new distributor into my 92 Tempo GL.
The car was running fine before the installation, but now it doesn't want to go when I accelerate. Also, the engine idles very high, and the engine overheats as a result.
Does anybody have an idea what's causing the high idle and the poor acceleration?
Jul 12, 2006 at 4:13 PM
TAURUSWHEEL
  • 718 POSTS
Is that engine ovrhead cam??? Barring another sudden issue happening, most likely something is, was not 100% aligned when you inserted the distributor, maybe you should r & r the thing, make sure all your ducks are lined up in a row.. xometimes retarded timing will cause the engine to run hot,, or is it possible you left something in the engine compartment out of place, unhooked???
Jul 12, 2006 at 5:45 PM
SKINNYGUY1981
hi. have you tried changing the idle stop solenoid? i had the same problem with an 85 tempo. it would rev high and you just pounded the solenoid a couple of times and it would rev normally. try replacing that
Jul 16, 2006 at 12:33 PM
