87 Ranger NO SPARK
1987 ALL OTHER MAKES ALL OTHER MODELS
NAI1ER
  • 15 POSTS
ranger has 2.3 FI 4cyl engine 45,000 miles. It had a dead number 2 cylinder Had spark and gas but dead. Turned out to be head gasket blown between #2 and #3 cylinder. After changing the head gasket I now have NO spark at all. I replaced the coil and pick up coil but still no spark. I am getting power to the primary side of coil but nothing from the secondary. From what I've been able to find out the problem must be in the " P I P " signal. I have tried several sources but to no avail I had good spark before replacing the head gasket. I did nothing to the ignition system except R&R spark plug wires . ( Yes they are back right ) The truck sat for a year and the battery went dead if that matters ?/? I'm at a loss. I had the ignition module bench tested ... good. Only thing left is the computer.
Any help would be appreciated.
Nai1er
May 24, 2006 at 5:39 PM
TCOOPER
  • 8 POSTS
:shock: change the rotor.It sometimes keeps it from firing.
Aug 31, 2006 at 9:13 PM
NAI1ER
  • 15 POSTS
So far I have changed the coil, pick up coil in the distributor, module and coil wire. Still no spark what so ever coming from the coil. I have power on both sides of the primary side of coil but nothing, not even a weak spark coming out.
Sep 2, 2006 at 9:35 PM
