84 Ranger 6cyl cooling system troubles
1984 ALL OTHER MAKES ALL OTHER MODELS
TONES1628
ranger was not building any temperature so I replaced temp sensor which did not help then I replaced the thermostat. now I am building temp but it runs all the way up to the high end of normal and never seems to open the thermostat.
Any help would be greatly appriciated.
Feb 2, 2006 at 3:43 PM
CHEVY350GUY
  • 109 POSTS
when you replaced the thermostate did you flush the system clean?
Feb 2, 2006 at 4:38 PM
TONES1628
yes the system was flushed
Feb 2, 2006 at 5:12 PM
CHEVY350GUY
  • 109 POSTS
it sounds like you have a faulty thermostat. it is probably worth it to put another one in because its temperature controlled, and if it is getting that hot, the thermostat has to be bad.
Feb 2, 2006 at 5:47 PM
TONES1628
was leaning that way just pulled it out and put it in an old pot with water and a digital thermometer and watch to see what temp it opened. temp was right 199 deg F which is what the manual called for.
Feb 2, 2006 at 5:57 PM
CHEVY350GUY
  • 109 POSTS
the only other thing i can think of is the water pump is worn out and not circulating properly. try this grab the pump pully and shake it . it should not move.
Feb 2, 2006 at 6:58 PM
