74 Cheyenne Dead Fuse Box
1974 ALL OTHER MAKES ALL OTHER MODELS
RMANGRU
My beloved 74 Cheyene, full sized, owned since 74, has a puzzling problem.
Electrically, it is completely dead.
The fuse box has no power at all. It will not start, has no lights, no nothing.
I have confirmed that the batter is good, alll battery cables and connections are good...all four fuseable links under the hood are good also.
It will start using a remote start switch between the battery and starter coil, but then dies.
It's completly dead at the fuse box.
Any ideas?
Thank you.
Rick Mangrum
Bentonville, AR
Feb 23, 2007 at 10:11 PM
CHEVY22
  • 1,375 POSTS
have you pulled the fuse box apart and checked for corrosion or any melting ?? if you have power all of the way to the box but nothing coming out i would start there and see what you find and let us know , i will monitor the post by email and respond as soon as i can
jim
Feb 23, 2007 at 10:28 PM
RMANGRU
I will try that tomorrow. It looks ok to the eye but I'll pull it off the firewall and check it out.
I'll come back tomorrow.
Thanks a lot.
Feb 23, 2007 at 10:31 PM
CHEVY22
  • 1,375 POSTS
no problem , i dont have any info on anything that old but you really shouldnt need any , very basic system , and you sound like you knwo what your doing so we can get this figured out
thanks jim
Feb 23, 2007 at 10:38 PM
RMANGRU
Jim,
Thanks very much for your response. Your advice was right on track.
However, I found the problem.
The dealer's service manual for this truck says there are four fuseable links under the hood.
WRONG!!
There are five.
The fifth one is embedded in the wiring harness, not visible, along the firewall.
As a last resort, before starting to take things apart under the dash, I cut open the wiring harness all around the engine.
There is was. I replaced it with a 30 amp fuse holder.
Thanks for your help. I really do appreciate your response.
Rick
Feb 24, 2007 at 4:02 PM
CHEVY22
  • 1,375 POSTS
no problem im glad to see it was fixed with little time and money ,
take care
Feb 24, 2007 at 4:35 PM
