4 runner 94 3.0
1994 ALL OTHER MAKES ALL OTHER MODELS
4-RUNNER
i spun a bearing but ive been told i can change them without taking the motor out . which leaves me to believe that this is common . how can i tell if the crank is damaged and if there is still some bearing protecting the rod and crank would it be ok . ive changed them but their not the right size. so ima change them again. i guess what im asking is since the bearing material is so much softer thatn the rod and crank . it shopuld be ok right? the bearing was squished but it was still separating the rod from the crank. please respond asap thanks ........4 runner
Jan 1, 2007 at 4:53 PM
Dirt is the major enemy on engine rebuilding. you can use a plastigage to read the clearance and then decide to go undersize bearings.No funds -like back in the old days we'll use leather instead of bearings for quick fix for DIY's.
You need to investigate why those bearings when bye-bye. might be a bent crank,taper or out of round. Best fix is to get a crank kit.
Jan 4, 2007 at 4:37 AM
