2nd gear
ALL OTHER MAKES ALL OTHER MODELS
JUANCBX3
  • 30 POSTS
i go to first gear then to second on my manuel trany and put it in normally and pops it out but if i hold it hard and then go it stays and let it go what could it be? Please help
Mar 20, 2006 at 11:30 AM
PEPPERMRJ
  • 1,158 POSTS
Second gear is actually not "going in all the way". This can be caused by wear on the eyelet ends of the shift cables. They round out on both ends and excessive play developes. Check the grommet ends that attach to the transaxle shift arms. Some twisting movement is OK. There shouldn't be any large amount of play either up and down or back and forth without the shift arm moving.
The ends are not replaceable seperately. You must replace the entire cable. Best to do so in pairs.
Lubricating the eyelets at the transaxle might help. They should be lubricated once a year.
Good luck and let us know. :)
Mar 20, 2006 at 4:47 PM
JUANCBX3
  • 30 POSTS
because when i did a burn out in first then whent to second it didnt go in
Mar 23, 2006 at 2:12 PM
