2002 Rendezvous Electrical/computer issue
2002 ALL OTHER MAKES ALL OTHER MODELS
PPERNO001
I have a 2002 Rendezvous and all the gauges, lights, radio, flash on and off, click, tick, doors unlock, lock, you name it, it all goes awry. I was told the computer module was shot. I ordered a certified tested used one from Cherry Automotive. Changed them out, the same thing is happening with this one. I'm thinking that it is NOT the module and there is something else causing this to happen. Any suggestions as to what might be the problem? Thanks
Feb 23, 2007 at 6:21 PM
CHEVY22
  • 1,375 POSTS
the dealer is the best place to check this out they can read every module in the car with the tech2 scanner , there are many things it could be , maybe just updated software for the pcm or bcm , the check out time will cost you less than replacing parts,
just an educated gm certified tech;s opinion :D lol
Feb 23, 2007 at 6:54 PM
GARYPSU
[quote:17acc71513="pperno001"]I have a 2002 Rendezvous and all the gauges, lights, radio, flash on and off, click, tick, doors unlock, lock, you name it, it all goes awry. I was told the computer module was shot. I ordered a certified tested used one from Cherry Automotive. Changed them out, the same thing is happening with this one. I'm thinking that it is NOT the module and there is something else causing this to happen. Any suggestions as to what might be the problem? Thanks[/quote:17acc71513]
I have the exact same problem. It started last night, but was OK this morning. Have you found the solution?
Mar 8, 2007 at 8:21 AM
DENNYP
  • 1,824 POSTS
[quote:b7590296cf="GaryPSU"][quote:b7590296cf="pperno001"]I have a 2002 Rendezvous and all the gauges, lights, radio, flash on and off, click, tick, doors unlock, lock, you name it, it all goes awry. I was told the computer module was shot. I ordered a certified tested used one from Cherry Automotive. Changed them out, the same thing is happening with this one. I'm thinking that it is NOT the module and there is something else causing this to happen. Any suggestions as to what might be the problem? Thanks[/quote:b7590296cf]
I have the exact same problem. It started last night, but was OK this morning. Have you found the solution?[/quote:b7590296cf]sounds like bad body control module.I do not recommend aftermarket bcm for this.not to mention this module requires programming after replacement.
Sep 27, 2007 at 11:58 PM
GARYPSU
[quote="dennyp"][quote:23f88df5f9="GaryPSU"][quote:23f88df5f9="pperno001"]I have the exact same problem. It started last night, but was OK this morning. Have you found the solution?[/quote:23f88df5f9]sounds like bad body control module.I do not recommend aftermarket bcm for this.not to mention this module requires programming after replacement.[/quote:23f88df5f9]
I traded the Rendezvous for a Saturn Aura XR, never found the cause, or fixed it, but my research indicated BCM problem.
Sep 28, 2007 at 7:37 AM
