2000 Grand Marquis Shifting/OD/Traction Control Prob.
2000 ALL OTHER MAKES ALL OTHER MODELS
INTEGRAWORKS
After shampooing the 4.6L V8 engine in FLA. I am experiencing continual problems with the OD/Traction Control/Transmission Shifting while at speed on highway. When the accelerator is depressed slightly the temp gauge will peak & flash, the transmition seems to shift into passing gear (engine races) and the traction control light comes on on the dash. Symptoms are lessened by turning O/D off before hills. If the accelerator is not released immediately upon the symptom happening, the engine light will come on and the engine will turn off (at highway speed).
I have cleaned, lubricated and re-connected every electrical connector under the hood thinking moisture was the problem. I cannot seem to isolate a module that is responsible for the O/D, Traction Control or the Transmission downshift through Alldata but am sure there must be one somewhere.
Any help would be appreciated!
Mar 13, 2007 at 1:12 PM
MERLIN2021
  • 17,250 POSTS
It' sounds to me like you got some Shampoo in the tranny! Check the level and color if its a milky pinkish white...Bad!!! if its red like it should be Good!!!
Mar 13, 2007 at 3:57 PM
