Heater: The heater stopped working, for awhile the heater worked only if you put it on the maximum blowing setting, but none of the lower settings worked, and then it died. If I open the air control to allow flow in air, not circulating air, I get some heat. I think the heater coil is heating but there is no fan.
Thermostat?
Wiper fluid: The tank is full, none of the tubes are clogged, but when you try to use the wipre fluid nothing happens. I dont hear a motor running trying to push the fluid. I took one end of the house off and was able to blow liquid through the tubes and out of the wipre fluid outlets.
Any ideas?
Thanks for any help!!!
Thermostat?
Any ideas?
Jan 10, 2006 at 8:33 AM
