1999 C230 Komp window can not go up and down
1999 ALL OTHER MAKES ALL OTHER MODELS
DANGCUONG
the window front left and front right, some time not working, right now my front right totaly dead, any one had same problem. Is it prossible the window switch bad, one thing I had notice that,when I pressed the switch I did not hear any thing.
Thanks for your help
Apr 2, 2007 at 12:57 AM
GFIMOTORCARS
  • 673 POSTS
If you are not hearing anything when you depress the button more than likely your window motor is faulty. This will require removal of the door panel and window motor to replace.
Feb 15, 2009 at 10:32 PM
NAUGHTYTOUCHCOUPLE
  • 4 POSTS
the advice is incorrect. motors take a long time to wear out. if a window motor is bad it will drag long before it quits. most likely your switches are bad.
since all the switches are the same, take out one you know works and try it on the windows that don't.....
Mar 11, 2009 at 7:30 PM
ECOCONUT
There is an electrical problem somewhere. Open the trunk of ur car, remove the Negative wire from the battery for about 5 to 10 minutes then replace it and the window will work. At least it work for me. I have the same problem on the front windows of my 99 C230 they have a mind of their own.
Jan 5, 2010 at 6:21 AM
