1999 540i electrical problem
1999 ALL OTHER MAKES ALL OTHER MODELS
90 FORD BRONCO
When I get in and start up the check monitor tells me the "check rear lights", they are fine. Often the the yellow ABS, traction control and brake lights come on and will not go off. I had the brakes checked and they were fine. I have in the past (right before problem) jumped another car with a dead battery off the rear battery hook up in the trunk. I think this may have casued these issues. Not a good idea, now I have to cope. Any ideas? Thanks.
Apr 11, 2006 at 2:23 PM
MY1992DOC325I
Have a friend stand in the back and do a full light check, make sure that both plate lights come on the reverse lights, ect, then you might want to remove the ecu, cpu fuse's and dissconect the battery, then wait 20 min. reconect everything. It should reset the codes that light up. Good Luck
Regards,
Bret
Apr 15, 2006 at 3:35 AM
WSTRUTZ
I have a 2000 540i and I have recently experiences an identical problem. The "Check Rear Lights" message will appear each time I start the car up for about 2-3 weeks and then it will go away for a while.
Recently, by ABS, Brakes, and DSC lights will be on. Then, sometimes they do not.
I was just wondering if the above solution fixed your problem on your 1999 540i
Mar 4, 2007 at 6:16 PM
GEOFFGREIG
I have had this and believe it or not it was just a bad connection on one of the bulbs. (clean connections) Even one with blackened glass can cause this. A change in weather ie. dry or wet will give the intermittent problem. Cheers Geoff.
Apr 21, 2009 at 10:55 PM
