1998 ECLIPSE DOESN'T HAVE SPARK!!
1998 ALL OTHER MAKES ALL OTHER MODELS
BLACK WIDOW
  • 5 POSTS
I HAVE A 1998 ECLIPSE THAT CRANKS BUT DOESN'T HAVE SPARK. I CHANGE THE IGNITION CONTROL MODULE,THE IGNITION COIL PACK, THE CRANKSHAFT POSITION SENSOR, THE ECU, AND THE MFI (ASD) RELAY. SO IF ANYONE KNOWS WHAT I AM DOING WRONG OR COULD HELP IN THIS MAJOR PROBLEM I AM HAVING
Dec 19, 2006 at 11:27 AM
GREDDYRCNG
  • 4 POSTS
when you changed the ecu out did you reset the ECU?
Feb 4, 2007 at 3:41 PM
BENMODE
[quote:43a551b8ba="greddyrcng"]when you changed the ecu out did you reset the ECU?[/quote:43a551b8ba]
I agree. ECUs determine the quantity of fuel, the ignition timing and other parameters by monitoring the engine through sensors. These can include, MAP sensor, throttle position sensor, air temperature sensor, engine coolant temperature sensor.
It would make it freshen out the sensors.
Feb 16, 2007 at 2:30 AM
