1997 z24 engine knocking
1997 ALL OTHER MAKES ALL OTHER MODELS
MEGANRUSSELL87
I bought a 1997 z24 not even one year ago . it has 158,000km on it and it has recently started knocking. I have been told a couple of theories.. one being it has something to do with a piston and i need to rebuild my engine or that it could be something in the top end. The knocking doesnt go away, only when the clutch is in. It doesn't get worse or better even if it is warm or cold out. Any ideas as to what the problem could be?! thanks
Jan 31, 2007 at 10:08 PM
2CARPRO JACK
  • 11,533 POSTS
Depending on the speed of the noise, sounds like the bottom end is going away.By pushing in the clutch, you are shoving the crankshaft forward in the engine, thus stopping the noise, sounds like excesive end-play in the crank.GN did have piston problems, but they would change or go away with temperature changes.
Feb 1, 2007 at 8:10 AM
MEGANRUSSELL87
Hi I made a mistake with my question last time.. My engine does NOT knock when the engine is cold but once the engine is up to operating temperature the knocking starts.. does this mean a possible piston problem then? thanks
Feb 4, 2007 at 2:51 PM
2CARPRO JACK
  • 11,533 POSTS
Could evry well be.Is it a fast noise or kinda slow?
Feb 5, 2007 at 10:33 AM
MEGANRUSSELL87
It seems to knock with the speed of idle.. When I accelerate it gets faster, when I slow down it slows.
Feb 5, 2007 at 2:08 PM
2CARPRO JACK
  • 11,533 POSTS
Could be a piston, might have to be heard by a tech in person, sorry but noises are the hardest part of online help
Feb 5, 2007 at 3:55 PM
