1997 Grand Am engine problem
1997 ALL OTHER MAKES ALL OTHER MODELS
YOUNGBLOOD126
This past weekend a clicking started under the hood (almost as though the oil was low). After checking the oil levels i did add some since it was at the minimum line. The clicking continued for a bit then stoped. I drove some, then when i stopped and restarted the car the clicking resumed. Then something new: the engine lost about 50% of it's power during acceleration. I've listened to try to determine where the sound originates and it seems loudest directly over the engine. Also when checking the oil there is a greasy buildup on the bottom of the cap that is like a yellow/brown grease. It will idle fine but with clicking. I'm a poor college student trying to determine the problem before taking it to a shop. Please help give me some ideas.
Jan 24, 2006 at 4:52 PM
MVANNESSJR
  • 223 POSTS
Do you have the 2.4L engine? If so, our cars have a common problem. The 2.4L engines had a problem with the head gaskets. That "grease" in the oil may actually be coolant. If that is the case then you have a blown head gasket and the damage to the engine has already begun. I'd take it to a local shop and have them check the system.
Jan 25, 2006 at 12:38 AM
