1997 Ford Mustang Dents
1997 ALL OTHER MAKES ALL OTHER MODELS
180,000 MILES • 6 CYL • 2WD • MANUAL
MUSTANGMONKEYMOBILE
My hood has a dent on the exterior right above the latch. I have used a suction cup to pull it out, but once the hood is opened and closed again the dent is sucked back in; now a weak spot in the metal I guess. Is it possible to repair this permanently or is it cheaper to get a used replacement hood?
Aug 20, 2008 at 6:06 PM
BLACKOP555
  • 10,386 POSTS
either you can find out if the antiflutter foam is good and the latch isnt collapsed but that usually involves cutting the skin apart, reinforcing and welding closed again.
with that said id replace the hood.
or with the dent down you can bondo it.
Aug 20, 2008 at 7:38 PM
KISSES
  • 9 POSTS
Yes, those dents can't be done in just sucking it plus Mustang has this strong body and built. Just leave it to the mechanic and/or welding some parts. At least if it worked, you won't buy another hood. But that would be the last option.
Aug 22, 2008 at 3:00 AM
