Also, check that all of the wires you can get to are making firm connections and are not burnt or damaged. It sounds to me like either a short or a ground. Ground would probably be the first thing I would check because it is the easiest. If possible, get a wiring diagram of your car. I have a 96 sunfire as well and the Haynes manual I have has a decent diagram. You can check resistance to ground with a multimeter. The radio on and off is what would make me think it is not a ground at the battery. If the ground was at the battery it is likely you would have some trouble starting your car. Not sure how the sensors you mentioned indicate if they should be lit or not to the computer, but they may act as a digital 0, which equates to a ground or open. I am by no means a mechanic, but I know a good amount about electrical stuff, so I would say it may be as simple as a sensor gone bad or a loose wire. Since your stereo is affected, you may want to unhook it and see if there is a ground internal to the stereo. Not sure if that would affect indicator lights, but it is a relatively simple next step after checking the battery cables. Good luck! Hope that helps!
Jan 20, 2006 at 1:40 PM
