1996 Rodeo oil pressure
1996 ALL OTHER MAKES ALL OTHER MODELS
JRE133
My rodeo has 140k When the engine is cold the oil pressure is 40-60 psi'
After driving for about 10 minutes the oil pressue drops to about 25-30 at low speeds. but when I stop at intersections the oil drops to ZERO. Oil level is good - What can this be ? HELP
Jan 21, 2006 at 11:22 AM
2CARPRO JACK
  • 11,533 POSTS
try the oil pressure sender first, thats the cheapest place to start. Use the factory oil filter. If still low could be the oil pump
Feb 2, 2006 at 3:36 PM
JOUGH626
  • 55 POSTS
Also, make sure your running the correct weight of oil. Having a good pressure at start up and then alot less later tells me that the oil could be thinning too much when it heats up.
Jun 17, 2006 at 7:43 PM
