1996 Geo metro idels but floods when throttle is applied
1996 ALL OTHER MAKES ALL OTHER MODELS
CROFTX2
I have a 1996 geo metro 1.0L 3 cyl manual trans 140k miles
the car starts and idles but when i add throttle it dies.
i have a head with new exhaust valves, new timeing belt, new cat converter, new spark plugs, new wires,cap,rotor,new injector,new map sensor, new fuel filter,used throttle position sensor that checks out by the manual. timeing in on,
tested the fuel pump and fuel pressure and they are good. I did pull the spark plugs and they were wet with fuel pointing to flooding bad. the only things i can think of that i havent changed is the O2 sensors or the computer and that the book may be wrong on the TPI tesing? I am lost any help would be apriciated thank you
Apr 15, 2007 at 6:11 AM
2CARPRO JACK
  • 11,533 POSTS
If the TPS is working in range then i should be ok. Shorted o2 sensor or computer would be good places to start. O2 sensor first
Apr 16, 2007 at 11:16 AM
