1995 Mercedes 300D with fuel getting into the motor oil
1995 ALL OTHER MAKES ALL OTHER MODELS
JERRY ROBOCK
I recently had an injector replaced because it was leaking. I drove about 600 miles and then experienced the car start to race, and smoke out the exhaust. It happened a few times. I took it back to the mechanic and he thought it might be the lift pump or the injection pump. He replaced the lift pump (because it was a lot cheaper) and I have only driven 200 miles so far. I'm not sure the problem is fixed.
Are there other possibilities that would cause this. When I returned to the mechanic he drained the oil and found that there was a gallon of fuel in the crank case. This was getting into the combustion chamber and causing the run away condition. What would allow diesel fuel to get into the crankcase?
May 7, 2007 at 1:42 PM
DR LOOT
  • 2,311 POSTS
there are only two problems that can cause us,
1. Leaky injectors.
2. The injection pump is leaking from the front seal
Mar 3, 2009 at 11:47 PM
