Your heater core has gone bad or leaking. This is a major pain of a project, but one you can do yourself. You are going to have to take the ducting off the bottom and gain access to your heater core to see if it is bad or just the lines leaking going into it. Some cars you have to take the entire dash out to gain access, but hoepfully your will be easier.
Look under the hood and see where the two water hoses are going into the firewall, and that will give you an idea of about where it is located in the car.
You will have a total of 4 lines going in, but two are with the airconditioning system, and 2 are with the heater core system.
Good luck, and hopefully you will get away with less than a $100 fix.
On a side note, that radiator fluid will stink for ever if you dont clean it properly. Make sure you dry up all you can from under your carpet, and after you get it back together, have your carpets steam cleaned.
Jul 13, 2006 at 3:27 PM
