1993 Questions for all other cars not Changing Gears
1993 ALL OTHER MAKES ALL OTHER MODELS
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
MAGICA86
Hey guys! my Bolden Barina Hatchback wont change geras and sometimes the powersteering doesnt work.It alternates from changing into reverse or into all other gears meaning sometimes it doesnt change into any other gear save for 1st then it does but then it wont change into reverse.
Sep 1, 2008 at 10:26 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
This is a problem with these transmissions, you will have to go see a transmission specialist for a test & report there will not be much that you can do save make sure that the oil level is OK and its condition is OK as well.
mark (mhpautos)
Sep 11, 2008 at 6:03 PM
MAGICA86
thanks mate.....the car changes gears sometimes and sometimes it doesnt it gets hell weird when you are driving and you start revving like you are crazy...I guess I just have to get a new transmission the repairs maybe worth a new one...do you know whereor how to add more transmission fluid I have no clue,I tried looking everywhere.Thanks heaps
Sep 11, 2008 at 8:55 PM
MHPAUTOS
  • 31,937 POSTS
HI there,
the transmission dip stick should be at the front of the transmission, just in front of the distributor and next to the exhaust manifold, it will have a lever type lock i think and will be coloured red or yellow.
mark (mhpautos)
Sep 11, 2008 at 10:02 PM
MIMI86
Hi there,
I've had the same issue with my automatic 1993 barina, where it seems as though the gears gets stuck and it starts revving like your in neutral.
Ive taking mine to get replaced, but it seems as though the gear box the mechanic has replaced it with does the same issue, so theyre looking into it to see its not another issue!!!
Feb 9, 2010 at 3:35 AM
MHPAUTOS
  • 31,937 POSTS
Get them to run a scan and check for any transmission electrical faults .
mark
Feb 9, 2010 at 3:58 AM
