1993 lumina
1993 ALL OTHER MAKES ALL OTHER MODELS
GRIMMY523
While the brakeis depressed at idle speeds the car wants to stop and sometimes does also sometimes when you accelerate after a stop it boggs down. I have replaced the plugs and wires. The rpm gauge also fluctuates when at idle with the brake depressed.
Apr 16, 2006 at 6:37 PM
LOSONE
  • 1,616 POSTS
Simple, you have a bad brake booster that is leaking vacuum when you depress the pedal causing all sorts of wierd problems. Good Luck
Apr 16, 2006 at 6:41 PM
GRIMMY523
How can it be a bad brake booster when the rpm fluctuates even when i n park.
Apr 17, 2006 at 5:09 PM
LOSONE
  • 1,616 POSTS
A vacuum leak is a vacuum leak regardless. It is greater when you depress the brakes. In the past 40 odd years of garage ownership I have replaced hundreds of brake boosters. Good luck
Apr 17, 2006 at 5:36 PM
