1993 Grand Voyager Engine cannot be turned off!!!
1993 ALL OTHER MAKES ALL OTHER MODELS
HACKINGDAVE
Hi there, Please help me. I replaced the entire Engine in my 1993 Voyager. And I connected a ground conector to the Alternator incorectly and It Discharged my batery. So I then used a portable booster to start the engine but after starting and shuting off the engine a few Times. I was Unable to turn it off. An when I did it by unpluging the Battery I saw a lot of smoke from a Module near the Air Filter by the Baterry. I Correted the Ground connections and Replaced the Module. After 30 Minutes of idling the engine again I cannot turn engine off!.. A Friend told me that If I turn ignition off and engine continues to run it will for sure burn the module again if I Disconect Battery. Did I corrected the Ground Connection to late? Could I have damaged something else in the electrical system.. In order for me to turn off Engine I now Start the engine and without turning the Ignition Keys I am having to Open the Hood and disconect Battery. At least I do not see smoke anymore. Somebody told me to replace Power Regulator by I do not even know where to find it.
Feb 17, 2007 at 4:39 PM
KIN CHAN
  • 453 POSTS
yes ..u do ..if ur system contain capacitors ..u will burn some cap down...at this point u are not sureall ur wiring and possible some melt down parts ..u need a VW expert to go over ur car... long distant trouble shooting is too hard to pin point ur problem
Feb 19, 2007 at 6:02 AM
HACKINGDAVE
I will face reality and take it to a local Mechanic.
Thanks for your quick reply.
Feb 19, 2007 at 9:21 PM
