Have you found resolution to this?
Have you replaced the thermostat? Does the cooling fan turn on when the A/C is turned on? It should, but if not then it could be the fan. You can wire the fan directly to the battery to see if it runs. If it doesn't replace it.
I would not worry about the fan right now as the temperature not getting warm in the vehicle. Check that thermostat.
May 23, 2006 at 4:02 PM
