i have a 1993 chev lumina Z34. 220,000 klm. I just finished replacing the rear rotors, pads and calipers. I also serviced the front calapers,replaced the rotors and pads. The lines have been blead. I have tested the brake booster and everything seems to be fine with it. My problem is that when i apply the brake at a high speed or low speed the brakes will only slow the car to a stop.they will not grab the way that brakes should. what do you think the problem and cure is for this. also , the ABS is not working. Thank you in advance for your help. Mike
Aug 22, 2006 at 8:39 PM
