1993 Caravan is possessed
1993 ALL OTHER MAKES ALL OTHER MODELS
BRUCERHONDA
It sure seems like it…
There is no rhyme nor reason to this problem.
My van will run, then stall and usually not start for a period of time (a few minutes to 10-15 minutes) under following conditions:
1. Warm, Cold weather
2. usually after reaching operating temperature
3. on full, 1/2, or near empty tank
4. on acceleration, idle, coasting
No codes come up. There is full power when it stalls and engine will always crank.
I've had the problem since summer. Mechanics replaced fuel pump and filter, some relays, starter replaced last year.
Please help me deliver my van.
Feb 3, 2007 at 2:37 AM
BUBBA_KOSKI
  • 129 POSTS
you MAY have water in the tank. just siphon out the gas and examine, is there soot coming from your exhaust???
email me [email protected]
Feb 3, 2007 at 8:31 PM
CLEAVAGE4U
  • 69 POSTS
Intermittants can be a pain. Kinda sounds like a computer issue or wiring issue from the computer to the fuel pump and or ignition coil circuit.
Feb 3, 2007 at 9:28 PM
JNELSON
  • 4 POSTS
My 1989 3.0L Grand Caravan has issues like your's. I have had the ignition switch replaced, the ASD relay, and now the SBEC computer is on order. I have a feeling that this shoud fix my problem. My van will start, run, and then after shutting it off, it will crank but not restart until it thinks it is time. No juice to the + side of the coil or fuel pump. The check engine light, at pre-ignition, will NOT illuminate like it should. Weird but true.
Jeff@California
3-6-2007 The SBEC FIXED my problem. YES!
Feb 16, 2007 at 4:16 PM
