1993 300E Transmission
1993 ALL OTHER MAKES ALL OTHER MODELS
ZEK 300E
1993 300E 2.8 Benz with auto transmission, 125,000 miles. Transmission went out this morning (short grinding and then no forward motion; reverse is fine). I am assuming it needs the transmission replaced. If I am wrong, please advise. If correct, I have two questions:
1 - Does it matter who does the work? Is there anything special/unusual about MB transmissions that requires a MB specialist or dealer?
2 - Any reason not to use a rebuilt transmission? Am assuming that is all that is practical at this point and do not really want to sink a fortune into the car, although everything else is good and it ought to run a lot longer.
Thanks!
Feb 23, 2007 at 2:44 PM
CHEVY22
  • 1,375 POSTS
any shop should be able to handle the job , they are a little more expenside parts wise compared to American cars ,but they are made with higher quality parts ,i would have to say with no forward gear the problem is internal , check the fluid level and condition and this may give you an idea , dark and burned is not good , just check around locally before you have it repaired , there are many small shops out there with an a+rep do your homwork and you should not be disappointed
thanks
jim
Feb 23, 2007 at 10:00 PM
ZEK 300E
Thanks -- that is most helpful! Estimates have ranged from $2200-$4000, but I was able to locate a shop that a friend used and which will rebuild the transmission rather than replace. Parts are a little more expensive, as you indicate, but not as bad as I had expected. Here's hoping the Benz will be good for another 100,000 miles!
Feb 25, 2007 at 1:25 PM
CHEVY22
  • 1,375 POSTS
good luck on the overhaul
jim
Feb 25, 2007 at 1:29 PM
