1992 LeBaron Convertible doing weird things!!
1992 ALL OTHER MAKES ALL OTHER MODELS
BARBARA ANNE
  • 6 POSTS
92 LeBaronConvertible V6, - stalls right after starting. Also, front left signal light flashes on its' own, when car is running "is alarm system trying to cut in or shorting out system and causing this problem"?
Feb 10, 2006 at 12:10 AM
PEPPERMRJ
  • 1,158 POSTS
Pull the fuse/power to the alarm system and see if it solves the problem. Post back.
Feb 12, 2006 at 11:46 AM
BARBARA ANNE
  • 6 POSTS
[quote:5de455cfa7="Barbara Anne"]92 LeBaronConvertible V6, - stalls right after starting. Also, front left signal light flashes on its' own, when car is running "is alarm system trying to cut in or shorting out system and causing this problem"?[/quote:5de455cfa7]
I seemed to have solved the stalling problem, by cleaning three ground wires, which were grounded to the body, which came from the main fuse box assembly, located beside the battery. Seems to run great now, but left hand front signal light still flashes when park light is on???
Feb 12, 2006 at 10:11 PM
PEPPERMRJ
  • 1,158 POSTS
Great. :D
The signal sounds like a ground also. Check the bulb and socket.
Feb 13, 2006 at 4:49 PM
BARBARA ANNE
  • 6 POSTS
[quote:c39f0d2c3a="Barbara Anne"]92 LeBaronConvertible V6, - stalls right after starting. Also, front left signal light flashes on its' own, when car is running "is alarm system trying to cut in or shorting out system and causing this problem"?[/quote:c39f0d2c3a]
:( Thought I had the stalling problem fixed, but the other day, I went for a drive, and it stalled on me, apparently, just before it did, my lights were blinking off and on, hide away covers were opening and shutting like it was possessed. :(( I do not know what to do. :(( can anyone help me?
Feb 16, 2006 at 2:00 PM
