1992 Grand Am
1992 ALL OTHER MAKES ALL OTHER MODELS
TKLINCK
  • 8 POSTS
I have a 92 Grand Am, 6 Cylinder that has an intermitten idle. By this, I mean the engine revs up, the back down causing it to almost stall, and sometimes stall it out. I've done full tune-up on it, reset timing, replaced oxygen sensor and was checking into the MAP sensor, Knock sensor or IAC valve. Any ideas of where to start?
Jan 19, 2006 at 8:09 PM
TKLINCK
  • 8 POSTS
Or could it be the Throttle Position Sensor?
Feb 2, 2006 at 8:15 AM
CHEVY350GUY
  • 109 POSTS
first clean as far in to the throttle chamber as you can. then remove iac valve and clean it's port. if idle remains the same i would start with the iac valve because you said it happens when you are at idle.
Feb 2, 2006 at 10:09 AM
