1992 1500 W/T Charging problem
1992 ALL OTHER MAKES ALL OTHER MODELS
SSGTSHIV
Hi, I replaced my alternator and serp. belt and ran the truck for 30 min. to make sure that everything was good. A couple of hours later my wife took the truck to the store and the battery light came on after getting the truck home I pulled the batt. and had it tested it was beyond help so I replaced it. I then double checked all connections and wires, but the new alt. is not charging the batt. I am only getting 8.5 to 9 volts to the battery. I checked several books and online but the only thing I found is a ref. in a hanes book to replace the coil. Will repaceing the coil do the job or is the voltage regulator in the new alt. the problem.
thanks in advance for your help with this.
May 12, 2007 at 8:05 PM
AUTOPOP
  • 49 POSTS
Have new alternator load tested.
Just because they are new doesn't mean it's good.
good luck
May 18, 2007 at 10:21 AM
