1990 delta 88 123427 millage
1990 ALL OTHER MAKES ALL OTHER MODELS
BIGT5104
  • 6 POSTS
car starts and idols for hours no problem when driving it seems sluggish and surges check engine is giving a code 42 and 43 replaced ecm and ignition coil last year need some help to check next
Aug 28, 2006 at 11:02 AM
MIKEYBDMAN
  • 623 POSTS
[quote:a468a98d88="bigt5104"]car starts and idols for hours no problem when driving it seems sluggish and surges check engine is giving a code 42 and 43 replaced ecm and ignition coil last year need some help to check next[/quote:a468a98d88]
I would turn to the knock sensor side of the equation. Does your engine knock when you accelerate? If so, fix the ause of the knock. If not, suspect a faulty KS or circuit.
Aug 28, 2006 at 2:19 PM
BIGT5104
  • 6 POSTS
[quote:6382140276="Mikeybdman"][quote:6382140276="bigt5104"]car starts and idols for hours no problem when driving it seems sluggish and surges check engine is giving a code 42 and 43 replaced ecm and ignition coil last year need some help to check next[/quote:6382140276]
I would turn to the knock sensor side of the equation. Does your engine knock when you accelerate? If so, fix the ause of the knock. If not, suspect a faulty KS or circuit.[/quote:6382140276]
theres no knock at all engine sounds great just runs sluggish and surges thanks i'll give that a look[/quote]
Aug 29, 2006 at 11:46 AM
BIGT5104
  • 6 POSTS
that worked thanks[quote:660ecf9d97="bigt5104"][quote:660ecf9d97="Mikeybdman"]
[quote:660ecf9d97="bigt5104"]car starts and idols for hours no problem when driving it seems sluggish and surges check engine is giving a code 42 and 43 replaced ecm and ignition coil last year need some help to check next[/quote:660ecf9d97]
I would turn to the knock sensor side of the equation. Does your engine knock when you accelerate? If so, fix the ause of the knock. If not, suspect a faulty KS or circuit.[/quote:660ecf9d97]
theres no knock at all engine sounds great just runs sluggish and surges thanks i'll give that a look[/quote:660ecf9d97][/quote]
Sep 12, 2006 at 11:10 AM
