1988 Questions for all other cars ignition timing
1988 ALL OTHER MAKES ALL OTHER MODELS
INSPECTORQ3
Engine Performance problem
1988 Questions for all other cars Front Wheel Drive Manual
i have a puegeot 405, 1.9l petrol single carb engine (d2d). i need to set the ignition timing to 7deg.btdc to accomondate unleaded petrol. there are 2 timing marks on block near flywheel. 1 is tdc and the other is 10deg. btdc. how do i alter it to be 7 degrees bdtc, which mark would i use. the gun i have just got is a sealey tl85. if i zero the t.light the mark on f.wheel meats tdc. so should i set the t.light to 3 and
move dizzy back until i get tdc. hence getting 7deg btdc
Jun 4, 2008 at 1:28 PM
KHLOW2008
  • 41,814 POSTS
Hi inspectorq3,
Set the timing light to 7 degrees and timing should show TDC 0 degrees.
Jun 8, 2008 at 3:20 AM
