1986 Questions for all other cars 1986 Mallard Motorhome - R
1986 ALL OTHER MAKES ALL OTHER MODELS
77,000 MILES • V8 • FWD • AUTOMATIC
KYLEBUSH
While trying to loosen the radiator drain valve, the torque caused the value base to crack it is now spitting out engine coolant. Is there a repair for the crack in the radiator? Can I flush/replace the coolant without using the drain in the bottom of the radiator? Thanks!
May 2, 2010 at 10:32 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, the radiator will have to be removed and the lower tank replaced or repaired, at this time they can replace the drain cock with a new unit that will not cause you the same problem.
Mark (mhpautos)
May 3, 2010 at 6:21 AM
