If they all stopped at the same time, my first suspect is the circuit breaker. Do me a favor. Use a test light and probe one pin at a time where you removed the circuit breaker from. One should have power when the key is in the on position.
If there is power, check the circuit breaker. Use a multi meter set to ohms and see if there is continuity from one pin to the other.
If that checks good, then we need to check the tan wire on the main switch (driver's side). All of the windows get power from that switch. Also, confirm the ground is good. (see the attached picture).
Sep 12, 2020 at 6:45 PM
