I need to know the alignment specs; camber caster and on a six inch lift.
Apr 18, 2019 at 8:28 PM
CERTIFIED EXPERT
Welcome to 2CarPros.
To the best of my knowledge, the lift shouldn't change anything. I attached the specs for this vehicle. Let me know if you have other questions. I also noted that you listed this as a 2wd. I'm not sure if that is correct, so I'm adding specs for both 2 and 4wd.
Apr 18, 2019 at 9:35 PM
VIVIANA OLAGUEZ
MEMBER
Fyi it’s diesel. doesn’t make a difference correct my tire size doesn’t affect it.
Apr 18, 2019 at 10:15 PM
CERTIFIED EXPERT
Any time you change the vehicle's height, it will need aligned. I punched in for the 6.4L which is the diesel. As far as alignment specs, they remain the same.
Apr 19, 2019 at 6:56 PM
VIVIANA OLAGUEZ
MEMBER
Okay, so I went off the specs you gave me and 8 haces the Moog caster camber part and I’m a little confused on dialing it in or what it should look like.
