I was preparing to change the timing belt so I pulled the timing belt cover off. Was lining up notches by turning crank with the belt on. As I was turning, everything slipped. I thought I had stripped the crank bolt, broke my ratchet or my socket. Upon inspection, all were fine. What I did find was that the belt was missing about 10 -15 teeth. Now previously, when I pulled the timing belt cover off, I had noticed some metal shavings a couple pieces of small, twisted shrapnel, and a bearing cover from the geared roller/cog. Upon further investigation, I noticed the geared roller/cog was missing a few bearings and surmised the pieces of shrapnel was what was left of the bearings. The crank and cams off the mark now and I am concerned that they were not lined up when I opened the timing belt cover to begin with.How should I go about lining everything up without the aid of the old belt? Can I simply rotate the cams so they are lined up with the notches and then do the same with the crank?
Dec 9, 2014 at 7:15 PM
