2001 Alfa Romeo 156 car wont start
2001 ALFA ROMEO 156
NEQ1982
Engine Mechanical problem
2001 Alfa Romeo 156 Two Wheel Drive
my car broke down today after overhesting and now it wont start whats the likeliest problem?
Dec 25, 2009 at 12:04 PM
No start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Dec 25, 2009 at 4:40 PM
