1999 Alfa Romeo 156 WONT START
1999 ALFA ROMEO 156
BEANER36
Engine Performance problem
1999 Alfa Romeo 156 Two Wheel Drive Manual
MY ALFA 156 TWIN SPARK TAKES TIME TO START IN THE MORNIG THEN WHEN SHE DOES START IF U TURN IT OFF SHE STARTS FIRST TIME TILL U LEAVE IT FOR SAY 4 HOURS
Sep 11, 2009 at 2:53 PM
Next time it refuses to start check what's missing fuel or spark
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sep 11, 2009 at 5:51 PM
