Connect scanner to portal, scanner comes back with "vehicle not responding". Why?
Aug 8, 2017 at 5:57 PM
CARADIODOC
CERTIFIED EXPERT
The ignition switch has to be in the "run" position. You may be using a scanner that is too new. 1995 and older vehicles use an older computer language, and none of the different manufacturer's systems were standardized.
Aug 9, 2017 at 3:54 AM
STEVE W.
CERTIFIED EXPERT
What scanner are you using? As Doc says that is an OBD I vehicle. I would also verify that you have power with the key on.
