Alarm will not disable
1999 MITSUBISHI ECLIPSE
138,000 MILES
MELANIE DABEL
I have to take the negative cable off every time I park, because the lights stay on and I have to pull the horn fuse. it does nothing but blow every time I go someplace. it is a pain.
Feb 13, 2019 at 1:09 PM
It sounds like the system needs to be rebooted. You can do this by disconnect the battery, then turn the ignition key on, then reconnect the battery. This guide can help as well:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Feb 15, 2019 at 6:54 PM
MELANIE DABEL
I did everything you said , it still won't reset. The lights stay on, the horn honks steady (had to pull fuse). Please help, thanks.
Feb 23, 2019 at 1:05 PM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
What lights come on? Can you be a little more specific please? Is it the headlights, taillights, interior lights, all the above? Thank you.
Thanks,
Alex
2CarPros
Does your remote work? Also, is the security light flashing?
Feb 23, 2019 at 1:07 PM
