Airflow leak, DPF light is on?
2019 VOLKSWAGEN CADDY
40,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
LEONBROD
Hi, my van had an EGR problem, so I got the EGR deleted. Now I have an air flow leak problem and the DPF light is on.
Oct 11, 2023 at 11:49 AM
First, this vehicle isn't offered in the US, but I will try my best to help.
As far as the airflow issue, have you checked to see if there is anything open as far as the EGR is concerned? I realize you deleted it, but if this started since that was done, chances are that is where the issue is located.
As far as the DPF light, that is likely the result of the leak.
Let me know. Also, let me know what was done for the EGR delete.
Oct 11, 2023 at 8:01 PM
