Thanks FLOBS for the addition to this post as that is good info.
You are correct that a flashing light does not directly mean that the system is low on charge. Meaning if the light is flashing then you need to add freon and that is the only solution.
However, Ken said it "usually" means it is low on charge and this is accurate.
The flashing light means that the HVAC control module has shut off the compressor because it is seeing an issue that could damage the compressor if it continues to run. This includes high and low system pressures or any of the issues that you mentioned as well.
On this site, the most common cause of A/C issues is by far incorrect charged systems. This mostly started when the "DIY fill cans" became popular. The reason is, when people have an A/C issue, they get a can and fill their system assuming that it is low and then they overcharge it.
So we have found that we need to start with checking the charge of the system just to make sure that is correct before we get down the road on something else.
This vehicle has a dual pressure sensor so if the system is low or high it will tell the HVAC module and it will cut the compressor. However, it will flash the AC light if the charge is low enough that the switch cut it off.
In this case, the member informed us that as soon as they put the gauge on it went straight to the red, which means it was overcharged and most likely tripped the high pressure switch and the module cut the compressor. At this point, it will flash the A/C light telling you that it cut the compressor due to an issue.
While we don't know the result as they never came back, it is pretty safe with that info to know he probably corrected the pressures and it corrected the issue.
You are correct that this can also be due to an electrical issue or sensor issue but there is not one correction for this flashing light.
Because of that, it is advisable for anyone who has a flashing light or other A/C performance issue to start with checking pressures. This is just a basic system check that can often put us on the right path if the pressure is correct or not. No different then telling someone to check their oil level when the oil light comes on.
Let us know if there are issues we can help you with in the future. Thanks
Jul 16, 2021 at 2:07 PM
