What size torx is used to remove the bolts on the steering wheel airbag?
2012 NISSAN ALTIMA
148,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
DWARREN
MEMBER
1 POST
FOLLOW
I have a set of star tools with a hole in the middle, but the holes are too small. It seems like it may be a T27 but the hole needs to be larger.
Sep 18, 2022 at 4:28 PM
CERTIFIED EXPERT
You will need the long reach torx bits check them out in the link below for $13.00 from Amazon. Also, I have included how to remove the driver side airbag in the images below. Make sure you disconnect the battery first.
